[mapguide-users] Map scales inaccurate by %13.528
Traian Stanev
traian.stanev at autodesk.com
Thu Oct 9 09:52:47 PDT 2014
Yes, this will also be an issue, even if the map is in a projected coordinate system. A physical measurement on the monitor will be off by the ratio of actual display resolution to 96 (which is the default used for map scale).
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Hans Milling
Sent: Thursday, October 09, 2014 6:01 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Map scales inaccurate by %13.528
This is not simply because your monitor is not 96 DPI? I think that MapGuide defaults to 96 DPI as screen resolution. A 1920x1080 monitor can be 16" or 32" and there is no way for the browser to tell MapGuide this. Howerver if you generate a PDF or image the scale should be correct (Except if you print the PDF and do not select "actual size" in the print dialog.
Best regards
Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Map-scales-inaccurate-by-13-528-tp5166479p5166644.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
