[mapguide-users] MapGuide as a Docker container
Jackie Ng jumpinjackie at gmail.com
Mon Oct 13 23:04:55 PDT 2014
Do you know what the fault tolerance story is with docker? What happens if
mgserver or httpd dies/crashes within the container? supervisord (which I
used in my example docker images) supposedly can take care of this, but I
have yet to be able to confirm.
Also in my tests, httpd becomes unreachable after a running docker container
is restarted. Does this happen for you as well?
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-as-a-Docker-container-tp5163934p5167333.html
