[mapguide-users] MapGuide Open Source 3.0 test build for 64-bit Linux
Michele Mondelli mithenks.ml at gmail.com
Tue Oct 14 08:28:44 PDT 2014
Hi Jackie
Some problems:
 - the arch variables in the script still point to i386, must be amd64
 - on a fresh installed centos-6.5 from minimal disc, you need also to
install package wget, libxslt and libpng
Hints:
 - use wget -c to download the tarballs, in case the download fail or is
interrupted for some problems
An updated script is atteched.
I'll run some tests and report back if possible.
Thanks for your work, it's very appreciated here!
Regards,
2014-10-14 14:12 GMT+02:00 Jackie Ng <jumpinjackie at gmail.com>:
> Hi All,
> You've been asking for it. Now you get it!
> Here's the first test build of the next version of MapGuide Open Source.
> You will need 64-bit CentOS (6.x) to try out this build or if you want to
> be
> creative, try running it within a CentOS-based Docker container (although
> you'll have to make your own docker image here)
> Download:
> http://download.osgeo.org/mapguide/releases/3.0.0/x64_Test1/mginstallcentos.sh
> Please test this build and report back on the general quality and stability
> of MapGuide and its FDO providers.
> Ubuntu 12.04 64-bit build will follow shortly.
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/MapGuide-Open-Source-3-0-test-build-for-64-bit-Linux-tp5167443.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
*Michele Mondelli*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141014/9f422763/attachment.html>
Type: application/x-sh
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141014/9f422763/attachment.sh>
