[mapguide-users] Centos Mapguide 2.6 Oracle provider missing
Riccardo Pucci
riccardo.pucci at dbcaditaly.com
Fri Oct 17 06:45:26 PDT 2014
I'm pretty sure is Linux-wide. It depends on sizeof wchar_t which is
compiler specific: on Windows (visual c++) is 2 byte while on Linux
(gcc) 4 byte.
When Haris switched from UTF-8 to UTF-16 charset to perform oracle
connection, used wchar_t to pass/retrieve string to oracle. In windows
it's ok because UTF-16 and wchar_t have the same size, in Linux a
shrink/deflate should be performed each time there's need to copy data
from/to wchar_t array to/from the UTF-16 array, as some OCI wrapper
does. (OCILIB for example).
I tried in the past to modify the provider in a such way, but I never
been able to have a fully functional provider, and finally I gave up.
Il 17/10/2014 02:18, Jackie Ng ha scritto:
> Is this a Linux-wide issue or specific to one particular distro?
> - Jackie
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Centos-Mapguide-2-6-Oracle-provider-missing-tp5167230p5167915.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
