[mapguide-users] php - edit map in repository, save modifications back
Hans Milling
hm at geograf.dk
Wed Oct 22 00:09:44 PDT 2014
Using the Maestro API you can load the MapDefinition from MapGuide, then
modify this (add layer or whatever) and use the:
code example:
Best regards
Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/php-edit-map-in-repository-save-modifications-back-tp5168012p5168813.html
