[mapguide-users] tooltips in 2.6 (migration from 2.2. to 2.6)
Andrew DeMerchant andrew.demerchant at gemtec.ca
Tue Oct 28 13:01:35 PDT 2014
I'm testing out some of my old MGOS 2.2 projects in 2.6 and one problem
I'm having so far is that some of my more fancy tooltips don't seem to
be showing up anymore. I've got some tooltips that show iframes with
some dynamic content (depending on the data that you're hovering over).
None of these are working in either Fusion or AJAX using 2.6...no idea
why. What's more, none of my tooltips work at all (even the simple ones)
in Fusion.
As a side note, I'm noticing that selecting using the ajax viewer in 2.6
seems require that you draw a box around the object, rather than just
clicking on it...any way I can change that back to the old way? Fusion
seems to let you click - but not the viewer. I suppose that if I get the
tooltips working in Fusion, then maybe I will finally be able to get rid
of the ajax viewer - jury's still out on that though.
Andrew
GEMTEC Email Signature
GEMTEC Limited <http://www.gemtec.ca/>
*Andrew DeMerchant*
tel: 506.453.1025  /  toll-free: 1.877.243.6832
fax: 506.453.9470
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141028/dbdd3436/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141028/dbdd3436/attachment.png>
