[mapguide-users] Any version of MGOS 64bit on Linux available?
Jackie Ng jumpinjackie at gmail.com
Tue Sep 2 21:03:41 PDT 2014
The existing test suites can reveal these issues.
1. Can be revealed by running the SHP unit test executable. Certain spatial
index queries will return extents that have minx/miny of 0 instead of some
arbitrarily negative number based on the test spatial data.
3. Can be revealed by running the Rendering Service test suite in MapGuide.
You can confirm that it is incorrect AGF binary data being fed into FDO by
creating the FDO query geometry via a raw WKT text transfer into with
MgWktReaderWriter instead of AGF binary transfer via MgAgfReaderWriter.
4. Can be revealed by running the Mapping Service test suite in MapGuide.
The process will segfault.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Any-version-of-MGOS-64bit-on-Linux-available-tp5158750p5159772.html
