[mapguide-users] MapGuide Maestro load GDB
mrfarhankhan at gmail.com mrfarhankhan at gmail.com
Tue Sep 23 19:15:27 PDT 2014
Thanks steve. Let me try this
On Tue, Sep 23, 2014 at 11:33 PM, Steve G [via OSGeo.org] <
ml-node+s1560n5163576h89 at n6.nabble.com> wrote:
> I have yet to attempt to load file geodatabases into MGOS but
> theoretically you should be able to load using MGOS 2.5 and above using OGR
> feature provider with a couple caveats.  See the following webpages for ogr
> drivers:
> http://www.gdal.org/drv_filegdb.html
> http://www.gdal.org/drv_openfilegdb.html (read access only, requires OGR
> 1.11)
> For FileGDB driver to work, OGR has to be compiled with FileGDB API
> library which I do not think is compiled by default with the OGR version
> packaged with MGOS.  If you are using Windows, you can get a compiled
> version of OGR with FileGDB through the OSGeo4w (
> http://trac.osgeo.org/osgeo4w/).
> When you get all the back-end stuff figured out, add a new resource using
> the OGR provider to connect to the file geodatabase in Maestro.  Once you
> get to the FDO provider screen and if you are connecting to the data using
> a alias file/directory, right click on the box next to DataSource and under
> Value which will open a prompt window to choose the data source.
> Hope this helps getting you started...please report back to the group your
> success/failures.
> -Steve
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/MapGuide-Maestro-load-GDB-tp5163416p5163576.html
>  To unsubscribe from MapGuide Maestro load GDB, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5163416&code=bXJmYXJoYW5raGFuQGdtYWlsLmNvbXw1MTYzNDE2fDUyOTgxNTY3OA==>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Maestro-load-GDB-tp5163416p5163625.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140923/5d36eefd/attachment.html>
