[mapguide-users] _sMapTitle Property in FUSION?
Jackie Ng jumpinjackie at gmail.com
Sat Sep 27 01:11:23 PDT 2014
If this is a 2.6 install, Fusion uses the new mapagent CREATERUNTIMEMAP
response to initialize everything (bypassing a request chain to various
slower PHP scripts).
The CREATERUNTIMEMAP response only carries the map name, and doesn't carry
anything resembling a map title. So the method that shapes this response
into something that the existing PHP scripts return probably just uses the
same map name as the title.
Is some widget in Fusion affected by this change?
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/sMapTitle-Property-in-FUSION-tp5163944p5164506.html
