[mapguide-users] [2.5.2]Error message DbEnv::txn_begin: DB_RUNRECOVERY: Fatal error
Rémy Gourrat
rgourrat at ag-carto.fr
Mon Sep 29 00:44:35 PDT 2014
When i build some tiles with mgcooker (6.0.a3) and defaults parameters connected to a mapguide 2.5.2,
After many hours, I see in error the log a strange message repeated thousands and thousands times.
But the Mapguide server continues to respond to mgcooker queries during long hours and write this message in the error Log :
<2014-09-28T23:03:20> 4344 Administrator
Error: An exception occurred in DB component.
DbEnv::txn_begin: DB_RUNRECOVERY: Fatal error, run database recovery
StackTrace:
- MgTimedEventHandler.handle_timeout() line 130 file c:\working\build_area\mapguide\2.5.2\x64\mgdev\server\src\core\TimedEventHandler.cpp
- MgResourceChangeEventHandler.HandleEvent() line 76 file c:\working\build_area\mapguide\2.5.2\x64\mgdev\server\src\core\ResourceChangeEventHandler.cpp
- MgServiceManager.DispatchResourceChangeNotifications() line 541 file c:\working\build_area\mapguide\2.5.2\x64\mgdev\server\src\common\manager\ServiceManager.cpp
- MgServerResourceService.EnumerateParentMapDefinitions() line 1539 file c:\working\build_area\mapguide\2.5.2\x64\mgdev\server\src\services\resource\ServerResourceService.cpp
- MgRepositoryManager.CreateTransaction() line 144 file c:\working\build_area\mapguide\2.5.2\x64\mgdev\server\src\services\resource\RepositoryManager.cpp
In the same time, If I try to display a map in a browser, often Mapguide fails to load the map and fails to generates the tiles .
I must restart the MapGuide service.
Someone have an idea to optimize the mapguide server ?
I see some parameters in config ini, but it's the first time i see this message in mapguide server and i worked on others mapguide server for the same works without problem.
thanks for you help
Rémy
AG-Carto - Bayonne
View this message in context: http://osgeo-org.1560.x6.nabble.com/2-5-2-Error-message-DbEnv-txn-begin-DB-RUNRECOVERY-Fatal-error-tp5164662.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140929/732af6a8/attachment.html>
