[mapguide-users] Package loading fails
Iulia Tamas iulia_tamas30 at yahoo.com
Fri Apr 17 05:22:17 PDT 2015
Hello,
When I try to load a package of 107 MB from MapGuide Site Administrator, it fails with :
ERROR_MESSAGE:    An exception occurred in DWF component. File not found in archive
STACK_TRACE:    - MgLibraryRepositoryManager.LoadResourcePackage() line 183 file c:\working\build_area\mapguide\2.5.2\x64\mgdev\server\src\services\resource\LibraryRepositoryManager.cpp - MgResourcePackageLoader.Start() line 150 file c:\working\build_area\mapguide\2.5.2\x64\mgdev\server\src\services\resource\ResourcePackageLoader.cpp - MgResourcePackageLoader.CreateByteReader() line 108 file c:\working\build_area\mapguide\2.5.2\x64\mgdev\server\src\services\resource\ResourcePackageLoader.cpp - MgZipFileReader.ExtractArchive() line 61 file c:\working\build_area\mapguide\2.5.2\x64\mgdev\server\src\services\resource\ZipFileReader.cpp
I am using Mapguide 2.5.2 64Bit. The mapguide version on wich the package was created is the same. The package was created using MapGuide Site Administrator also.
Any ideas?
Thank you,Iulia
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20150417/f19a2a2a/attachment.html>
