[mapguide-users] Server stops working after 2-3 days
Franco Caloni
franco.caloni at stacec.com
Thu Apr 30 02:24:26 PDT 2015
Hi all,
MG 2.6 64bit on Windows Server 2008 R2/IIS.
I'm experiencing a stability problem on my production server.
My application works fine on both my development machine (Win 7, VS2013, C#)
and the server, but on the server, after some time it stay up (and works),
let's say 2-3 days, it stops working giving this error (in Event Viewer):
Process information:
Process ID: 6464
Process name: w3wp.exe
Account name: IIS APPPOOL\MapGuide26AppPool
Exception information:
Exception type: MgResourcesLoadFailedException
Exception message: Failed to load the resource file
"Resources/mapguide_en.res" for locale "en".
at MgInitializeWebTier line 131 file InitializeWebTier.cpp
at MgInitializeWebTierInternal line 102 file InitializeWebTier.cpp
at MgResources.LoadResources line 338 file
c:\working\build_area\mapguide\2.6.0\x64\mgdev\common\foundation\System/Reso
urces.cpp
==== [C++ <-> .net] ====
in
OSGeo.MapGuide.MapGuideApiPINVOKE.SWIGExceptionHelper.ThrowCustomException(S
tring className, IntPtr cptr)
in OSGeo.MapGuide.MapGuideApiPINVOKE.MgInitializeWebTier(String jarg1)
in CityGis.Ente.GoCartografia.Page_Load(Object sender, EventArgs e)
in System.Web.UI.Control.LoadRecursive()
in System.Web.UI.Page.ProcessRequestMain(Boolean
includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Request information:
Request URL: theUrl
Request path: thePath
User host address: TheServerIP
User: theUserName
Is authenticated: True
Authentication Type: ApplicationCookie
Thread account name: IIS APPPOOL\MapGuide26AppPool
Thread information:
Thread ID: 9
Is impersonating: False
Stack trace: in
At this point I have to manually restart the application pool (not recycling
it, but restarting), and the application works again for 2-3 day then I have
the same error again....
I already given to "Everyone" and "IIS APPPOOL\MapGuide26AppPool" users
full control on resource folder (which is not under "Program" folder), but
still have the problem.
It seems an application pool setting problem but can't figure what is (I
didn't changed the setting the MG setup made on AppPool when I installed it)
any ideas?
Thanks
Franco
