[mapguide-users] API - resource id does not refer to a valid feature source
Fritz Robert
Robert.Fritz at win.ch
Tue Aug 11 06:39:37 PDT 2015
I changed the data source from local path to alias per PHP script.
For SDF/SHP files this works fine.
For raster data I get a problem:
-- raster files are not displayed
-- Mapguide log file shows an entry where Mapguide complains that file doesn't exist (still pointing to the local path)
-- in MapGuide Studio the data source connection (using the alias) is fine (Test: ok) but when I open a layer which refers to the data source I get "resource id does not refer to a valid feature source"
I can solve the issue manually when I just save the data source connection in Studio.
But how can I solve/avoid the issue using PHP API?
Any ideas?
Rob
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20150811/42000040/attachment.html>
