[mapguide-users] MGOS release 3.0 and Commercial maps
pcardinal
pierre.cardinal at sympatico.ca
Thu Aug 27 16:30:25 PDT 2015
MGOS 3.0 is "buggy" with commercial maps. Everything was OK with MGOS2.6 but
with MGOS 3.0 it is impossible to use commercial maps.
Fusion Error
Error
Error Details:Exception occurred in AJAX callback.
Message: Caractère incorrect
Inner Stack: SyntaxError: Caractère incorrect
at window.Fusion.parseJSON
(http://localhost/mapguide/fusion/lib/fusionSF-compressed.js:33:328)
at parseMapTip
(http://localhost/mapguide/fusion/lib/fusionSF-compressed.js:3096:467)
at Anonymous function
(http://localhost/mapguide/fusion/lib/fusionSF-compressed.js:1171:465)
at respondToReadyState
(http://localhost/mapguide/fusion/lib/fusionSF-compressed.js:2057:587)
at onStateChange
(http://localhost/mapguide/fusion/lib/fusionSF-compressed.js:2055:421)
Response:
Invalid argument(s):
The map display width cannot be less than or equal to zero.
- MgRenderingServiceHandler.ProcessOperation() line 83 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
- MgOpQueryFeatures.Execute() line 125 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
- MgServerRenderingService.QueryFeatures() line 1092 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\rendering\ServerRenderingService.cpp
- MgServerRenderingService.RenderForSelection() line 1459 file
Stack Trace:
- ? at http://localhost/mapguide/fusion/lib/fusionSF-compressed.js (line:
54)
- window.Fusion.parseJSON at
http://localhost/mapguide/fusion/lib/fusionSF-compressed.js (line: 33)
- parseMapTip at
http://localhost/mapguide/fusion/lib/fusionSF-compressed.js (line: 3096)
- respondToReadyState at
http://localhost/mapguide/fusion/lib/fusionSF-compressed.js (line: 2057)
- onStateChange at
http://localhost/mapguide/fusion/lib/fusionSF-compressed.js (line: 2055)
- window.Fusion.ajaxException at
http://localhost/mapguide/fusion/lib/fusionSF-compressed.js (line: 32)
- dispatchException at
http://localhost/mapguide/fusion/lib/fusionSF-compressed.js (line: 2058)
- onStateChange at
Source:
http://localhost/mapguide/fusion/templates/mapguide/slate/index.html?Session=3853ae2a-4d0d-11e5-8000-90b11c9f31d3_en_MTI3LjAuMC4x0AFC0AFB0AFA&ApplicationDefinition=Session:3853ae2a-4d0d-11e5-8000-90b11c9f31d3_en_MTI3LjAuMC4x0AFC0AFB0AFA//0a2938f0-b617-49a3-bea1-509e224950d9.ApplicationDefinition&locale=en
MapDefinition
<?xml version="1.0"?>
<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0"
xsi:noNamespaceSchemaLocation="MapDefinition-2.4.0.xsd">
<Name />
<CoordinateSystem>PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular
Visualisation Pseudo
Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]</CoordinateSystem>
<Extents>
<MinX>-8237000</MinX>
<MaxX>-8174000</MaxX>
<MinY>5678000</MinY>
<MaxY>5737700</MaxY>
</Extents>
<BackgroundColor>ffffffff</BackgroundColor>
<Metadata><MapDescription>test</MapDescription></Metadata>
<Watermarks />
</MapDefinition>
<ApplicationDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="ApplicationDefinition-1.0.0.xsd">
<Title>Slate</Title>
<TemplateUrl>fusion/templates/mapguide/slate/index.html</TemplateUrl>
<MapSet>
<MapGroup id="testMap">
<Map>
<Type>MapGuide</Type>
<SingleTile>True</SingleTile>
<Extension>
<ResourceId>Library://Test/testMap.MapDefinition</ResourceId>
<Options>
<isBaseLayer>false</isBaseLayer>
<useOverlay>true</useOverlay>
<projection>EPSG:900913</projection>
</Options>
</Extension>
</Map>
<Map>
<Type>VirtualEarth</Type>
<SingleTile>true</SingleTile>
<Extension>
<Options>
<name>Bing Maps Street</name>
<type>Road</type>
</Options>
</Extension>
</Map>
</MapGroup>
</MapSet>
<WidgetSet>
<Container xsi:type="UiItemContainerType">
<Name>Toolbar</Name>
<Type>Toolbar</Type>
</ApplicationDefinition>
View this message in context: http://osgeo-org.1560.x6.nabble.com/MGOS-release-3-0-and-Commercial-maps-tp5221559.html
