[mapguide-users] setSelection() 2.5 Fusion bug?
amorsell
andy.morsell at autodesk.com
Tue Feb 24 17:37:27 PST 2015
I'm wondering if someone can confirm that this is an issue with 2.5 Fusion
(AIMS 2015).
1. Open a Fusion map that has a Search widget defined in it
2. Use the Search widget to search for something
3. Select a search result to zoom to it and verify that the Selection panel
shows the attributes for that feature (search.templ uses the setSelection()
method here)
4. Use the select tool to select a different feature on the map and verify
that the Selection panel shows the attributes for that feature
5. Select a search result. Verify that it zooms but the selection panel
still shows the attributes for the previously selected map feature. (this
is the bug)
Once this happens, all subsequent calls to setSelection() will exhibit this
behavior until the Fusion layout is reloaded.
Thank you for any help.
View this message in context: http://osgeo-org.1560.x6.nabble.com/setSelection-2-5-Fusion-bug-tp5189832.html
