[mapguide-users] FDO libraries for RHEL 7.0
Jackie Ng
jumpinjackie at gmail.com
Thu Feb 26 16:21:15 PST 2015
MapGuide and FDO were not built nor tested against RHEL 7.0 (I assume the
open equivalent is CentOS 7)
In such cases, you can either try to re-compile MapGuide and FDO against
RHEL 7 or consider running MapGuide within a docker image based on Ubuntu 12
or CentOS 6 and install an existing supported Linux build of MapGuide inside
it.
Here's an example Dockerfile you can use (using the CentOS build of MapGuide
2.6)
https://github.com/jumpinjackie/mapguide-centos-docker/blob/master/Dockerfile
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/FDO-libraries-for-RHEL-7-0-tp5190234p5190384.html
