[mapguide-users] kaliopa mobile viewer, doesn't show map
Srecko Lipovsek srecko.lipovsek at kaliopa.si
Fri Jul 3 13:02:23 PDT 2015
Open Chrome hit F12 open Console tab if there is some error ...
-------- Izvirno sporočilo --------
Od: "Emma Schmidt [via OSGeo.org]" <ml-node+s1560n5214145h57 at n6.nabble.com>
Datum: 03. 07. 2015 10:45 (GMT+01:00)
Za: Srečko Lipovšek <Srecko.Lipovsek at kaliopa.si>
Zadeva: Re: kaliopa mobile viewer, doesn't show map
--> Sorry, it was the wrong topic
  *   I can see the Weblayout with the Ajax Viewer
  *   I tried the wms layer as normal Layer and as Base Layer, it doesn’t work at all in the mobile Viewer
  *   The wgs84 pseudo mercator projekction doesn’t work as well.
It’s strange because the Legend and the Layer On/off works. Which tells me, that the connection is right and the Layout works fine with the Ajax Viewer, what can be wrong?
Do I need to set something in the IIS except the  “ Create virtual directory and Convert it to Application ” . Or any other settings?
Thanks
mapguide-users mailing list
[hidden email]</user/SendEmail.jtp?type=node&node=5214145&i=0>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/kaliopa-mobile-viewer-doesn-t-show-map-tp5213987p5214145.html
To unsubscribe from kaliopa mobile viewer, doesn't show map, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5213987&code=c3JlY2tvLmxpcG92c2VrQGthbGlvcGEuc2l8NTIxMzk4N3w4NDkwMzc2MTc=>.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/kaliopa-mobile-viewer-doesn-t-show-map-tp5213987p5214259.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20150703/570007da/attachment.html>
