[mapguide-users] kaliopa mobile viewer, doesn't show map
Srecko Lipovsek
srecko.lipovsek at kaliopa.si
Thu Jul 9 05:21:41 PDT 2015
It depends in wich folder did you put this application and how it is
configured in IIS.
KaliopaMobileViewer folder should be at the same level as folder mapagent
(not inside of it !).
It should be in folder www:
eg.: c:\mapguide_xxx\Web\www\
Then just "Convert to Application" in IIS is needed and it should work.
View this message in context: http://osgeo-org.1560.x6.nabble.com/kaliopa-mobile-viewer-doesn-t-show-map-tp5213987p5215051.html
