[mapguide-users] Fwd: Consultation mapguide to be send
Hans Milling hm at geograf.dk
Mon Jul 20 03:46:37 PDT 2015
Hi Julian
If you have the vehicles on the MapGuide map, the entire map image is
reloaded/generated, every time you need to refresh the vehicle positions.
What I have done in my solution is:
1. From JavaScript call the server (an aspx/php) that returns all vehicles
positions in JSON format.
2. Add a vector layer to the OpenLayers map with the vehicles on top of the
MapGuide map.
3. Keep updating the vehicle data, eg. every 5 seconds from the server.
This way the MapGuide server is not used, unless I zoom/pan the map, even
though the vehicles are moving on the map. The load on the server is far
less this way.
Best regards
  Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Fwd-Consultation-mapguide-to-be-send-tp5215466p5216221.html
