[mapguide-users] [MapGuide 2.5.2 Maestro 6.0.0.8244]Composite Symbolization MTEXT
Rémy Gourrat rgourrat at ag-carto.fr
Tue Jul 28 02:12:54 PDT 2015
I try to use Composite Symbolization MTEXT with an expression in Text Content.
Before, i valided this expression in a simple point display like text:
concat('Id : ',ASSET_ID,'\nZt. : ',COTE_TAMPON,'\nProf. : ',PROFONDEUR,'\nRad. : ',RADIER)
This label point displays with 4 lines and it's fine.
but when i use it in Composite Symbolization MTEXT, the MTEXT on the map is only one line.
Is it possible to offset the MTEXT ? I try PositionX and PositionY but not success.
I can't have access to Offset property with Maestro for MTEXT
My XML Definition
<?xml version="1.0"?>
<CompositeSymbolization xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
  <SymbolInstance>
    <SimpleSymbolDefinition>
      <Name>MTEXT</Name>
      <Description>Default MTEXT Symbol</Description>
      <Graphics>
        <Text>
          <Content>%CONTENT%</Content>
          <FontName>%FONTNAME%</FontName>
          <Bold>%BOLD%</Bold>
          <Italic>%ITALIC%</Italic>
          <Underlined>%UNDERLINED%</Underlined>
          <Overlined>%OVERLINED%</Overlined>
          <Height>%FONTHEIGHT%</Height>
          <PositionX>%StyleEditorGenerated_TextPositionX_0%</PositionX>
          <PositionY>%StyleEditorGenerated_TextPositionY_0%</PositionY>
          <HorizontalAlignment>%HORIZONTALALIGNMENT%</HorizontalAlignment>
          <VerticalAlignment>%VERTICALALIGNMENT%</VerticalAlignment>
          <Justification>%JUSTIFICATION%</Justification>
          <LineSpacing>%LINESPACING%</LineSpacing>
          <TextColor>%TEXTCOLOR%</TextColor>
          <GhostColor>%GHOSTCOLOR%</GhostColor>
          <Frame>
            <LineColor>%FRAMELINECOLOR%</LineColor>
            <FillColor>%FRAMEFILLCOLOR%</FillColor>
            <OffsetX>0</OffsetX>
            <OffsetY>0</OffsetY>
          </Frame>
          <Markup>'MTEXT'</Markup>
        </Text>
      </Graphics>
      <PointUsage>
        <Angle>%ANGLE%</Angle>
      </PointUsage>
      <ParameterDefinition>
        <Parameter>
          <Identifier>CONTENT</Identifier>
          <DefaultValue>concat('Id : ',ASSET_ID,'\nZt. : ',COTE_TAMPON,'\nProf. : ',PROFONDEUR,'\nRad. : ',RADIER)</DefaultValue>
          <DisplayName>T&amp;ext</DisplayName>
          <Description>Text</Description>
          <DataType>Content</DataType>
        </Parameter>
        <Parameter>
          <Identifier>FONTNAME</Identifier>
          <DefaultValue>'ArialNarrow'</DefaultValue>
          <DisplayName>&amp;Font Name</DisplayName>
          <Description>Font Name</Description>
          <DataType>FontName</DataType>
        </Parameter>
        <Parameter>
          <Identifier>FONTHEIGHT</Identifier>
          <DefaultValue>8</DefaultValue>
          <DisplayName>Font &amp;Size</DisplayName>
          <Description>Font Size</Description>
          <DataType>FontHeight</DataType>
        </Parameter>
        <Parameter>
          <Identifier>BOLD</Identifier>
          <DefaultValue>false</DefaultValue>
          <DisplayName>Bold</DisplayName>
          <Description>Bold</Description>
          <DataType>Bold</DataType>
        </Parameter>
        <Parameter>
          <Identifier>ITALIC</Identifier>
          <DisplayName>Italic</DisplayName>
          <Description>Italic</Description>
          <DataType>Italic</DataType>
        </Parameter>
        <Parameter>
          <Identifier>UNDERLINED</Identifier>
          <DisplayName>Underlined</DisplayName>
          <Description>Underlined</Description>
          <DataType>Underlined</DataType>
        </Parameter>
        <Parameter>
          <Identifier>OVERLINED</Identifier>
          <DisplayName>Overlined</DisplayName>
          <Description>Overlined</Description>
          <DataType>Overlined</DataType>
        </Parameter>
        <Parameter>
          <Identifier>JUSTIFICATION</Identifier>
          <DefaultValue>'FromAlignment'</DefaultValue>
          <DisplayName>Justification</DisplayName>
          <Description>Justification</Description>
          <DataType>Justification</DataType>
        </Parameter>
        <Parameter>
          <Identifier>LINESPACING</Identifier>
          <DefaultValue>1.05</DefaultValue>
          <DisplayName>Line Spacing</DisplayName>
          <Description>Line Spacing</Description>
          <DataType>LineSpacing</DataType>
        </Parameter>
        <Parameter>
          <Identifier>GHOSTCOLOR</Identifier>
          <DefaultValue />
          <DisplayName>Ghost Color</DisplayName>
          <Description>Ghost Color</Description>
          <DataType>GhostColor</DataType>
        </Parameter>
        <Parameter>
          <Identifier>FRAMELINECOLOR</Identifier>
          <DefaultValue />
          <DisplayName>Frame Line Color</DisplayName>
          <Description>Frame Line Color</Description>
          <DataType>FrameLineColor</DataType>
        </Parameter>
        <Parameter>
          <Identifier>FRAMEFILLCOLOR</Identifier>
          <DefaultValue />
          <DisplayName>Frame Fill Color</DisplayName>
          <Description>Frame Fill Color</Description>
          <DataType>FrameFillColor</DataType>
        </Parameter>
        <Parameter>
          <Identifier>TEXTCOLOR</Identifier>
          <DefaultValue>0xff000000</DefaultValue>
          <DisplayName>Text Color</DisplayName>
          <Description>Text Color</Description>
          <DataType>TextColor</DataType>
        </Parameter>
        <Parameter>
          <Identifier>VERTICALALIGNMENT</Identifier>
          <DefaultValue>'Halfline'</DefaultValue>
          <DisplayName>&amp;Vertical Alignment</DisplayName>
          <Description>Vertical Alignment</Description>
          <DataType>VerticalAlignment</DataType>
        </Parameter>
        <Parameter>
          <Identifier>ROTATION</Identifier>
          <DefaultValue>0.0</DefaultValue>
          <DisplayName>&amp;Rotation</DisplayName>
          <Description>Rotation</Description>
          <DataType>Angle</DataType>
        </Parameter>
        <Parameter>
          <Identifier>HORIZONTALALIGNMENT</Identifier>
          <DefaultValue>'Left'</DefaultValue>
          <DisplayName>Hori&amp;zontal Alignment</DisplayName>
          <Description>Horizontal Alignment</Description>
          <DataType>HorizontalAlignment</DataType>
        </Parameter>
        <Parameter>
          <Identifier>StyleEditorGenerated_TextPositionX_0</Identifier>
          <DefaultValue>1</DefaultValue>
          <DisplayName>PositionX</DisplayName>
          <Description>PositionX</Description>
          <DataType>Real</DataType>
        </Parameter>
        <Parameter>
          <Identifier>StyleEditorGenerated_TextPositionY_0</Identifier>
          <DisplayName>PositionY</DisplayName>
          <Description>PositionY</Description>
        </Parameter>
      </ParameterDefinition>
    </SimpleSymbolDefinition>
    <ParameterOverrides>
      <Override>
        <SymbolName>MTEXT</SymbolName>
        <ParameterIdentifier>StyleEditorGenerated_TextPositionY_0</ParameterIdentifier>
        <ParameterValue>1</ParameterValue>
      </Override>
      <Override>
        <ParameterIdentifier>StyleEditorGenerated_TextPositionX_0</ParameterIdentifier>
      </Override>
      <Override>
        <ParameterIdentifier>HORIZONTALALIGNMENT</ParameterIdentifier>
        <ParameterValue>'Left'</ParameterValue>
      </Override>
      <Override>
        <ParameterIdentifier>VERTICALALIGNMENT</ParameterIdentifier>
        <ParameterValue>'Halfline'</ParameterValue>
      </Override>
      <Override>
        <ParameterIdentifier>CONTENT</ParameterIdentifier>
        <ParameterValue>concat('Id : ',ASSET_ID,'\nZt. : ',COTE_TAMPON,'\nProf. : ',PROFONDEUR,'\nRad. : ',RADIER)</ParameterValue>
      </Override>
      <Override>
        <ParameterIdentifier>FONTNAME</ParameterIdentifier>
        <ParameterValue>'ArialNarrow'</ParameterValue>
      </Override>
      <Override>
        <ParameterIdentifier>FONTHEIGHT</ParameterIdentifier>
        <ParameterValue>8</ParameterValue>
      </Override>
    </ParameterOverrides>
  </SymbolInstance>
</CompositeSymbolization>____________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________
Thanks for your help
Rémy
AG-Carto - Bayonne
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-2-5-2-Maestro-6-0-0-8244-Composite-Symbolization-MTEXT-tp5217316.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20150728/2457ba8c/attachment.html>
