[mapguide-users] mapguide-rest feature requests
RenoSun
renolionheart at gmail.com
Tue Jun 2 09:26:34 PDT 2015
1.mapguide-rest search results
For the GeoRest, if only one result is found, it will display page with
single templates. If there is no result will use None template. However,
mapguide-rest only uses the many templates to display the result to me when
there is only one/no records being found.
For example, there is no RNAME like NORTHT
http://localhost/mapguide/rest/data/property/.html?filter=RNAME%20LIKE%20%27NORTHT%25%27
2.BBOX filter and Coordinate Transformation
It will be a good feature if the mapguide-rest allow users to do spatial
query using BBOX with transformed coordinates if they are using transformto
URL parameters.
For example, the feature originally is in UTM84-10N coordinate system.
No Result
http://localhost/mapguide/rest/library/DatabaseName/FolderName/data/FeatureName.FeatureSource/features.geojson/dbo/Building?transformto=LL84&BBOX=-124.3991,49.35648,-124.3983,49.35709
Working (BBOX using original coordinate system)
http://localhost/mapguide/rest/library/DatabaseName/FolderName/data/FeatureName.FeatureSource/features.geojson/dbo/Building?transformto=LL84&BBOX=390000,5463999,400000,5468999
Thanks!!!
View this message in context: http://osgeo-org.1560.x6.nabble.com/mapguide-rest-feature-requests-tp5208708.html
