[mapguide-users] Maestro Python API get color of a line in a layer definition
Jérôme Touré j.toure at global-stern.com
Thu May 21 03:59:08 PDT 2015
Thank you Jackie,
That's where I was stuck. I should be able to complete my script now !
Jerome
Le 21/05/2015 11:10, Jackie Ng a écrit :
> Are you stuck at the line rule and don't know what property to go down to get
> to the symbolization settings? If so, you want to look at the Items property
> of the line rule which is a collection of strokes, each stroke contains the
> symbolization settings you're after.
> FYI. If the IronPython auto-complete doesn't help, you can always use help()
> on any variable to dump out all the properties and methods of that variable
> (along with any API documentation attached)
> - Jackie
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Maestro-Python-API-get-color-of-a-line-in-a-layer-definition-tp5206832p5206862.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Jérôme Touré
STERN
473 route des Dolines
Villantipolis 7
06560 VALBONNE
Phone : +33 4 92 96 96 01
Mobile : +33 6 27 84 04 30
Fax : +33 4 92 96 96 02
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20150521/5415af00/attachment.vcf>
