[mapguide-users] Using an external WMS in MapGuide Maestro
Herbert Schwarz
mc-storm at gmx.net
Wed Nov 11 03:02:09 PST 2015
Hello,
I currently started working with MapGuide OS. I want to integrate an
external WMS (https://geodienste.sachsen.de/wms_geosn_webatlas-sn/guest)
into MapGuide.
Am I right, that I have to use MapGuide Maestro to define the source?
If so, I already created a new Resource and a new Feature Source. The
feature Source is of type "WMS Provider". I entered the given URL address
into the Featurer Server textfield and tested to connect to the server.
Unfortunately I get the follwing error message:
Der Remoteserver hat einen Fehler zurückgegeben: (559) MgFdoException.:
An exception occurred in FDO component.
Error occurred in Feature Source
(Session:a2e445a4-885b-11e5-8000-005056b31877_en_MTI3LjAuMC4x0AFC0AFB0AFA//b6251f0e-df11-45e3-91a9-93ad724ec856.FeatureSource):
Unable to connect to the host.
- MgFdoConnectionManager.Open() line 333 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\common\manager\FdoConnectionManager.cpp
- MgFdoConnectionManager.CacheFdoConnection() line 1097 file
- MgFdoConnectionManager.Open() line 1089 file
(Cause: , Root Cause: )
- MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpGetSpatialContexts.Execute() line 105 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\OpGetSpatialContexts.cpp
- MgServerFeatureService.GetSpatialContexts() line 1293 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\ServerFeatureService.cpp
- MgServerGetSpatialContexts.GetSpatialContexts() line 100 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\ServerGetSpatialContexts.cpp
- MgFdoConnectionManager.Open() line 366 file
I have no idea, what to do now. I also searched for the directory c:\working
but couldn't find it.
Thanks for your help,
Herb
View this message in context: http://osgeo-org.1560.x6.nabble.com/Using-an-external-WMS-in-MapGuide-Maestro-tp5235696.html
