[mapguide-users] The map display width cannot be less than or equal to zero
Scott Hameister
scotth at mpowerinnovations.com
Thu Nov 12 06:42:44 PST 2015
You will need to have requested the map image at least once in a current
session and set scale and width and height before you can use many of the
other FCGI/REST calls on that session.
Is it possible you are firing this off before that when it happens
On Thu, Nov 12, 2015 at 7:23 AM, Emma Schmidt <emma.25 at gmx.net> wrote:
> Hey,
> what is the matter of this error "*The map display width cannot be less
> than or equal to zero*"?
> It's occurs sometimes when I do an OPERATION=QUERYMAPFEATURES. I can't see
> the reason because the same operation with the same attributes works fine a
> second before.
> There is no attribute called *map display **width *in the operation=
> QUERYMAPFEATURES
> I'm using MG 2.5 (64bit) and the mapviewernet (.NET).
> Many thanks for any help
> Regards
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
*Scott Hameister | www.mpowerinnovations.com
<http://www.mpowerinnovations.com/>________________________________________**mPower
Innovations*
1051 N Lynndale Drive, Suite 2A, Appleton, WI 54914
Main: (877) 269-6971 x 204 <%28877%29%20269-6971%20x%20207> | Mobile: (920)
419-6250 <%28920%29%20470-0292>
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20151112/e2e7118c/attachment.html>
