[mapguide-users] The map display width cannot be less than or equal to zero
Hans Milling
hm at geograf.dk
Fri Nov 13 00:46:27 PST 2015
I use the Maestro API, and I get this error if I create a runtime map with no
width/height information. So I always set the width/height to 1024x768 when
I create the RuntimeMap, and then later on I set the correct values.
View this message in context: http://osgeo-org.1560.x6.nabble.com/The-map-display-width-cannot-be-less-than-or-equal-to-zero-tp5235957p5236150.html
