[mapguide-users] Using an external WMS in MapGuide Maestro
Herbert Schwarz
mc-storm at gmx.net
Mon Nov 23 05:14:47 PST 2015
Hi Jackie,
I followed your suggestions regarding the configuration document.
However, if I try to show the preview the following error message appears:
Message: minx > maxx
Parametername: minx
Details: System.ArgumentException: minx > maxx
Parametername: minx
bei
Maestro.Editors.Preview.LocalMapPreviewer.<>c__DisplayClass4.<Preview>b__1(Object
obj, Exception ex) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
trunk\workspace\Maestro.Editors\Preview\LocalMapPreviewer.cs:Zeile 163.
bei Maestro.Shared.UI.BusyWaitDialog.Run(String message, BusyWaitDelegate
action, Action`2 onComplete, Boolean bPreserveThreadCulture) in
trunk\workspace\Maestro.Shared.UI\BusyWaitDialog.cs:Zeile 103.
bei Maestro.Editors.Preview.LocalMapPreviewer.Preview(IResource res,
IEditorService edSvc, String locale) in
trunk\workspace\Maestro.Editors\Preview\LocalMapPreviewer.cs:Zeile 160.
bei Maestro.Base.Editor.EditorContentBase.Preview() in
trunk\workspace\Maestro.Base\Editor\EditorContentBase.cs:Zeile 376.
bei Maestro.Base.Commands.PreviewResourceCommand.Run() in
trunk\workspace\Maestro.Base\Commands\PreviewResourceCommand.cs:Zeile 42.
bei ICSharpCode.Core.WinForms.ToolBarCommand.OnClick(EventArgs e)
bei System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
bei System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
bei System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e,
ToolStripItemEventType met)
bei System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e,
bei System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
bei System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons
button, Int32 clicks)
bei System.Windows.Forms.Control.WndProc(Message& m)
bei System.Windows.Forms.ScrollableControl.WndProc(Message& m)
bei System.Windows.Forms.ToolStrip.WndProc(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
m)
bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
IntPtr wparam, IntPtr lparam)
Does that mean that there is an error in the extends of the bounding box? I
checked the coordinates for the bounding boxes in the config.xml but
couldn't find any minx greater than maxx
Thanks,
Herb
View this message in context: http://osgeo-org.1560.x6.nabble.com/Using-an-external-WMS-in-MapGuide-Maestro-tp5235696p5238045.html
