[mapguide-users] SQL Server Spatial View Selection Issue
Gunter Becker
gunter.becker at csogis.de
Tue Oct 6 00:15:35 PDT 2015
If you have access to the database you can also recreate your view as an
"Indexed View". Only requirement is that you create your view with
"schemabinding":
Next, you can create a unique index on this view:
Afterwards you should be able to select features on your layer.
Gunter
View this message in context: http://osgeo-org.1560.x6.nabble.com/SQL-Server-Spatial-View-Selection-Issue-tp5228068p5228114.html
