[mapguide-users] Mapguide 3.0 and postgis/mssql datetime properties
Jamo
adam.jamison at portbris.com.au
Tue Oct 13 23:44:05 PDT 2015
Thanks it appears to be null they are both calling on the same property
approved_dt
I'm sure it's something simple .....
Response Body for feature properties
{"FeatureInformation":{"FeatureSet":[{"@xmlns:xsi":["http://www.w3.org/2001/XMLSchema-instance"],"@xsi:noNamespaceSchemaLocation":["FeatureSet-1.0.0.xsd"],"Layer":[{"@id":["a2e54812-722d-11e5-8000-0025b30aca2c"],"Class":[{"@id":["gisgeom:plndevapp"],"ID":["FQAAAAAAAAA="]}]}]}],"Hyperlink":null,"InlineSelectionImage":null,"SelectedFeatures":[{"SelectedLayer":[{"@id":["a2e54812-722d-11e5-8000-0025b30aca2c"],"@name":["devApp"],"Feature":[{"Bounds":["518216.84304321802
6972545.0184448296 518216.84304321802
6972545.0184448296"],"Property":[{"Name":["approved_dt"],"Value":*null*}]}],"LayerMetadata":[{"Property":[{"DisplayName":["approved_dt"],"Name":["approved_dt"],"Type":["3"]}]}]}]}],"Tooltip":null}}
Response Body for tooltip
{"FeatureInformation":{"FeatureSet":[{"@xmlns:xsi":["http://www.w3.org/2001/XMLSchema-instance"],"@xsi:noNamespaceSchemaLocation":["FeatureSet-1.0.0.xsd"],"Layer":[{"@id":["a2e54812-722d-11e5-8000-0025b30aca2c"],"Class":[{"@id":["gisgeom:plndevapp"],"ID":["FQAAAAAAAAA="]}]}]}],"Hyperlink":null,"InlineSelectionImage":null,"SelectedFeatures":null,"Tooltip":*["TIMESTAMP
'2015-02-27 13:29:31'"]*}}
MapGuide Maestro 6.0.0.8587
MapGuide Opensource 3.0.0.8701
Fusion, PHP, Apache
Windows 7 Pro SP1
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-3-0-and-postgis-mssql-datetime-properties-tp5229375p5229931.html
