[mapguide-users] How to use API (get selection geom) on Remote Server using a GETRUNTIMEMAP session ID?
Flipper
scotth at mpowerinnovations.com
Tue Oct 20 13:43:08 PDT 2015
I Am able to hit a remote machine do a CreateRuntimeMap CGI call and select
features in the session map with a QueryMapFeatures fcgi call.
What I can't figure out is how to get the Geometry of the selected objects
in the session or other relevant information.
I'd like to use the mapguide API in c# but on a remote server I can't quite
figure out how to get around the InitializeWebTier...isn't their a way to
get an MgMap/MgSite/ etc object by using the URL and SessionId of the
runtimemap without the need for an INI file...if it is required is their a
generic ini file i can place local to my code that should work on most
instances of Mapguide i.e MapguideOS and AIMS? I tried to Utilize the
Maestro Source code in Visual Studio to run a trace, but when I attempt to
Run it in Debug I receive over 650 errors, and manually tracing through the
code is really cryptic.
I also wondered if REST would do the trick but couldn't find enough
documentation to tell me if it would meet all the criteria.
string remotesite =
"http://www.remoteservername.com/mapguide/mapagent/mapagent.fcgi"
MgUserInformation mguserinformation = new
MgUserInformation(runtimemap.SessionId);
mguserinformation.SetMgSessionId(obj.SessionId); //just in case
//MgSite mgsite = new MgSite();
//MgSiteInfo MSI = new MgSiteInfo(remotesite, 2812, 2811, 2810); //TEST
//mgsite.Open(mguserinformation, MSI);//TEST
MgSiteConnection mgsiteconnection = new MgSiteConnection(remotesite);
mgsiteconnection.Open(mguserinformation);
This does not work
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-use-API-get-selection-geom-on-Remote-Server-using-a-GETRUNTIMEMAP-session-ID-tp5231522.html
