[mapguide-users] Mapguide 2.6 and 3.0 Can't run Mapadmin or mapagent?
Scott Hameister
scotth at mpowerinnovations.com
Thu Oct 22 17:26:15 PDT 2015
Thanks Mark...I got swamped and never corrected..I had to repoint the php
handler in IIS to the right one...no clue how it would have gotten
repointed between versions though
On Oct 22, 2015 7:07 PM, "Mark Volz (LeapCAD)" <mark at leap-cad.com> wrote:
> Hi,
> Have you confirmed that php & the Mapguide/php integration has been
> configured correctly on IIS.
> The simplest way of doing this is to create a php file in the www folder
> of your mapguide installation that contains the following code;
> <php
> Phpinfo();
> Once that has been created op http://localhost/mapguide/<newly created
> file>
> If it is all working you should see a page showing the installed &
> correctly running components of your php installation, & one of these items
> should be called Mapguide.
> Hope this helps
> Mark
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20151022/70d6d0b3/attachment.html>
