[mapguide-users] Upgrade Mapguide from 2.6->3.0
Jackie Ng jumpinjackie at gmail.com
Wed Sep 2 00:33:31 PDT 2015
Use the InstantSetup bundle instead of the windows installer.
The InstantSetup bundle just extracts to a directory of your choice, where
you can then run the included setup utility to init that particular
installation with the right port numbers and virtual directories. It will
also generate a series of batch files to install/start the various services
manually once configured.
Be sure to pick names and port numbers that don't clash with your existing
install.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upgrade-Mapguide-from-2-6-3-0-tp5222237p5222247.html
