[mapguide-users] WFS issues - index out of bounds
Mark Volz (LeapCAD) mark at leap-cad.com
Wed Sep 2 01:32:54 PDT 2015
Evening All,
I'm using MapGuide 2.6 to produce a WFS output.
Generally everything is working fine, however for 2 layers (out of 30) I am
receiving the following error;
 An exception occurred in FDO component.
Error occurred in Feature Source (Library://<folders> /WFS.FeatureSource):
Item index out of bounds.  (Cause: , Root Cause: Item index out of bounds. )
But if I set the MAXFEATURES = 400 everything works fine (there are just
under 700 records for this layer).
The layer contains both polygons and points,  the data source is Oracle and
I am using the SL king  FDO with control table (to remove the ~'s from layer
names). The data displays correctly as a layer in mapguide.
I've checked the data and there isn't any special characters (%, &, ~, !,
etc) in there.
Is there a file size / payload limit with WFS? There are some very complex
polygon's coming back.
Any thoughts or help would be greatly appreciated.
Thanks
Mark
