[mapguide-users] Wisconsin County Coordinate Systems Error on Transform
Flipper scotth at mpowerinnovations.com
Fri Apr 29 08:36:11 PDT 2016
In Mapguide Maestro I have a bunch of SQL Data projected into a Wisconsin
County Coordinate System. When I try to make a map utilizing any of these
layers they Have a projection error.
If I make a map in Any Wisconsin County Coordinate system and try to change
it to Another Coordinate System in the Area like Wisconsin State Plane,
LL84, Spherical Mercator I get this message.
"Failed to transform coordinates. Projection Transverse Mercator, Wisconsin
County Variation is not Supported."
Also try to set a mapdefinition view to extents of current layer crashes for
LL84 layers and all other layer projections I tried. "transformation failed"
I haven't tested the Minnesota County Coordinate systems yet, but id be
willing to bet they don't work either.
I'm pretty sure it isn't a maestro issue because when I set the appropriate
extents and preview the map no layers reproject to Wisconsin County Systems,
or vice versa County System to a mapdefinition in another system.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Wisconsin-County-Coordinate-Systems-Error-on-Transform-tp5263552.html
