[mapguide-users] Wisconsin County Coordinate Systems Error on Transform
Scott Hameister scotth at mpowerinnovations.com
Sat Apr 30 07:59:20 PDT 2016
Will try that Monday..if I force over-ride the coordinate system and known
extents mapguide does not do projection. So I rules out maestro
On Apr 30, 2016 4:14 AM, "Jackie Ng" <jumpinjackie at gmail.com> wrote:
> You can confirm if it's a MapGuide-level problem by doing the same
> transformation with the same coordinates and coordinate systems through
> mapguide-rest and seeing if it fails too.
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/Wisconsin-County-Coordinate-Systems-Error-on-Transform-tp5263552p5263635.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20160430/5a7e9448/attachment.html>
