[mapguide-users] mapguide and mssql low performance problem
Hans Milling hm at geograf.dk
Tue Aug 23 01:24:20 PDT 2016
Another great performance tip is to adjust what zoom levels different layers
are visible.
A building layer does not have to be visible when viewing a 100x100
kilometer area. Anything else that does not make sense drawing in the map
when zoomed all the way out should be set only visible in the inner zoom
levels.
Tweaking the different zoom levels that layers are visible can increase
performance quite a bit.
Also splitting a forrest layer (or other layer with many complex polygons)
in two, where you have a decreased the amount of points in the polygons for
the outer zoom levels and have the fully detailed polygons in the inner zoom
levels can speed up the map quite a bit. Most Desktop GIS application have a
feature to decrease the amount of points in polygons or lines. Imagine a
shore line with points for ever meter and you have to draw this at
1:1000000, most of the points in the shore line will fall within the same
pixel. Having a low detailed version for the first zoom levels will increase
performance a lot.
Best regards
  Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/mapguide-and-mssql-low-performance-problem-tp5276761p5281813.html
