[mapguide-users] Measure tool and tooltip in Fusion
RenoSun
renolionheart at gmail.com
Wed Aug 31 08:27:40 PDT 2016
The solution is as following:
Pragmatically Turn off MapTip?
<http://osgeo-org.1560.x6.nabble.com/Pragmatically-Turn-off-MapTip-td5106147.html>
Under FusionSF.js
Add following codes under
Fusion.Widget.Measure = OpenLayers.Class(Fusion.Widget, {
activate: function () {
this.control.activate();
this.getMap().message.info(OpenLayers.i18n("measureInProgress"));
this.resetMeasure();
OpenLayers.Event.observe(document, "keypress", this.keyHandler);
this.loadDisplayPanel();
this.getMap().supressContextMenu(true);
*//Disable maptip when measring
Fusion.getWidgetsByType('Maptip')[1].deactivate();*
deactivate: function () {
OpenLayers.Event.stopObserving(document, 'keypress',
this.keyHandler);
this.control.deactivate();
this.control.cancel();
this.getMap().message.clear();
this.getMap().supressContextMenu(false);
*//Enable maptip when measring tool is deactivate
Fusion.getWidgetsByType('Maptip')[1].activate();*
View this message in context: http://osgeo-org.1560.x6.nabble.com/Measure-tool-and-tooltip-in-Fusion-tp5283159p5283322.html
