[mapguide-users] MapGuide WFS returns empty response for geometry filter with >200 vertices
jpc joychua97 at gmail.com
Wed Feb 3 15:38:41 PST 2016
Hi everyone,
Did more investigation on this issue. although we still cannot find the
cause why a geometry filter with >200 vertices is returning an empty
response.
Could you please suggest another method to confirm the root cause or whether
this issue has been experienced elsewhere (and whether it is a core product
issue)?
1) FDO connection logging was switched on and only returns GET responses, it
does not show the bind variable data passed through via WFS to DB
2) Used Oracle DB trace to inspect WFS bind variable data with no success,
using following methods:
  - Monitoring SQLs within the AWR and ASH
  - Tracing sessions at the lowest level possible
Thank you.
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-WFS-returns-empty-response-for-geometry-filter-with-200-vertices-tp5244478p5248776.html
