[mapguide-users] ECW and MGOS 2.6.1
Philip Nell pnell at openspatial.com
Wed Feb 10 19:01:11 PST 2016
I am having troubles with ECW files not showing in MGOS 2.6.1 with the (new)
GDAL provider I got from here
https://trac.osgeo.org/mapguide/wiki/MGOSGdalProviderFor26And30
The error in the log file is:
“Cause: , Root Cause: Unable to load the FDO Provider library
'.\GRFPProvider.dll': The specified procedure could not be found.”
I use MGOS version = 2.6.1.8732 on Windows server/IIS with the GDAL provider
Jacki build copied to the FDO folder and the environment variable set.
(64bit)
When that new provider was not installed yet, the error was:
“Cause: , Root Cause: Only MOSAIC(), CLIP() and RESAMPLE() are supported.)”
Sorry if this is a dumb question or not allowed here…
Any assistance will be appreciated.
Philip Nell
View this message in context: http://osgeo-org.1560.x6.nabble.com/ECW-and-MGOS-2-6-1-tp5250027.html
