[mapguide-users] Select a feature after map loaded
GordonL
gordon.luckett at arrowgeomatics.com
Tue Feb 16 07:31:05 PST 2016
You have to wait until the map is loaded.
If you are using the AJAX (Basic Web Layout) then you can check out the
samples for that here:
https://trac.osgeo.org/mapguide/wiki/CodeSamples/JavaScript/AJAXViewerEventHooking
View this message in context: http://osgeo-org.1560.x6.nabble.com/Select-a-feature-after-map-loaded-tp5250336p5250857.html
