[mapguide-users] Remember Layers and Layer Groups On/Off settings - Fusion
RenoSun renolionheart at gmail.com
Tue Feb 23 09:44:00 PST 2016
Hello everyone,
Did anyone try to modify the MapGuide fusion to be able to remember the
Layers and Layer Groups On/Off settings by add and update following url
parameters?:
SHOWLAYERS (sl)
HIDELAYERS (hl)
SHOWGROUPS	(sg)
HIDEGROUPS (hg)
I am able to make our mobile viewer to remember the layer setting by url
parameters as following link:
http://maps.qualicumbeach.com/qbmap/mobileMapViewer/MobileMap.aspx?m=Property&blyr=TTFFFFFF&curextent=-13861739.90327515,6329092.982497331,-13843395.016486708,6338217.652748873&zoom=14&sl=QBZoning&hg=Airphotos,Building%20Permits&hl=QBRoads,QBBenches&sg=Parks
<http://maps.qualicumbeach.com/qbmap/mobileMapViewer/MobileMap.aspx?m=Property&blyr=TTFFFFFF&curextent=-13861739.90327515,6329092.982497331,-13843395.016486708,6338217.652748873&zoom=14&sl=QBZoning&hg=Airphotos,Building%20Permits&hl=QBRoads,QBBenches&sg=Parks>
Then, I can share this link to other users with the same based map, map
extent, and layers setting. Or if I accidentally refresh the page, I will
still be able to see the same map that I were using.
Now, my plan is to make our fusion maps to have the same function, and would
like to see if anyone has done that on fusion already.
Any ideas will be appreciated :) Thanks a lot!!!!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Remember-Layers-and-Layer-Groups-On-Off-settings-Fusion-tp5252306.html
