[mapguide-users] Map Guide Open Source 3.0 on HTML 5 on Desktops and Devices
Jackie Ng jumpinjackie at gmail.com
Thu Jul 21 06:12:05 PDT 2016
If you are intending to use Fusion as your viewer, it is mostly serviceable
on ios/android browsers. The viewer itself is already touch capable, but the
UI provided by the Fusion templates is very desktop-centric and you'll
probably need some development effort to build a phone/table-optimized
experience.
I do not recall MapGuide 6.5 supporting SQLite files. Are you referring to
SDF files? MG 6.5 supports SDF2 files, MGOS supports SDF3 files, which are
completely different. The commercial studio product from Autodesk can
convert SDF2 files to SDF3, but MapGuide Maestro does not have such
capabilities.
However, you have greater data source flexiblity in MGOS thanks to FDO, you
don't have to stick to SDF files, you can use SHP files, SQLite databases
and most relational database (Oracle, SQLServer, MySQL, PostgreSQL with
PostGIS)
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Map-Guide-Open-Source-3-0-on-HTML-5-on-Desktops-and-Devices-tp5275842p5277584.html
