[mapguide-users] Change Legend Title
Jackie Ng jumpinjackie at gmail.com
Thu Jul 21 06:19:39 PDT 2016
Under fusion/text, there are two files named:
 * en
 * en.json
These are your string bundles.
Rename both to es and es.json and translate all the strings inside from
English to Spanish.
I'm pretty sure that the key 'legendTitle' in en.json is what's used for the
floating window.
To get Fusion to use these strings, pass in locale=es in your viewer query
string, which Fusion should pick up and will use your es/es.json strings.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Change-Legend-Title-tp5276698p5277585.html
