[mapguide-users] QuickPlot or Printable Page not Printing Tiled Layers
RenoSun
renolionheart at gmail.com
Mon Jul 25 08:39:17 PDT 2016
Hi Gordon,
For AIMS 2014, I found only when I initially turned on the tiled layers, the
Quick Plot will print the tiled layers. Also, if you initially turned on the
tiled layers, even you turn them off after the map have been loaded. The
Quick Plot will still print the map with the tiled layers.
Do you have the same issue too?
View this message in context: http://osgeo-org.1560.x6.nabble.com/QuickPlot-or-Printable-Page-not-Printing-Tiled-Layers-tp5275805p5278029.html
