[mapguide-users] MapGuide Maestro 6.0M5 available
kdm koen.de.munter at geoit.be
Thu Jun 16 01:15:13 PDT 2016
Hi Jackie,
Installing MM 6.0m5 is not a problem, however, when I close MM I get the
following error message:
<http://osgeo-org.1560.x6.nabble.com/file/n5271970/error_mm.png>
In Event Viewer the 2 following errors are logged:
*source = .NET Runtime*
Application: Maestro.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.TypeInitializationException
Stack:
   at OSGeo.MapGuide.MapGuideDesktopApiPINVOKE.MgdPlatform_Terminate()
   at Maestro.AddIn.Local.Commands.StartupCommand.OnAppExit(System.Object,
System.EventArgs)
   at System.Windows.Forms.Application.RaiseExit()
   at System.Windows.Forms.Application+ThreadContext.Dispose(Boolean)
   at
System.Windows.Forms.Application+ThreadContext.RunMessageLoopInner(Int32,
System.Windows.Forms.ApplicationContext)
   at System.Windows.Forms.Application+ThreadContext.RunMessageLoop(Int32,
   at System.Windows.Forms.Application.Run(System.Windows.Forms.Form)
   at Maestro.Program+<>c.<Main>b__0_0()
   at Maestro.Base.Services.ServiceRegistry.Initialize(System.Action)
   at Maestro.Program.Main()
*source = Application error*
Faulting application name: Maestro.exe, version: 6.0.0.8909, time stamp:
0x570671a1
Faulting module name: KERNELBASE.dll, version: 6.1.7601.19135, time stamp:
0x56a1c79e
Exception code: 0xe0434352
Fault offset: 0x0000c52f
Faulting process id: 0x4b9c
Faulting application start time: 0x01d1c7a8725241b5
Faulting application path: D:\Program Files (x86)\OSGeo\MapGuide Maestro
6.0m5\Maestro.exe
Faulting module path: C:\Windows\syswow64\KERNELBASE.dll
Report Id: b6bf03df-339b-11e6-a920-000c29b1bec8
Do you have any suggestions what might be the problem?
.NET Framework 4.5.2 is installed.
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Maestro-6-0M5-available-tp5260150p5271970.html
