[mapguide-users] MapGuide Maestro 6.0M5 available
Jackie Ng
jumpinjackie at gmail.com
Thu Jun 16 18:37:54 PDT 2016
The installer might not have installed the MSVC 2012 redistributable
(required by mg-desktop for the Local Connection mode). Actually I'd have to
check if the installer even does that!
If you don't use this mode, you can basically ignore the error (as
ungraceful as it is currently).
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Maestro-6-0M5-available-tp5260150p5272119.html
