[mapguide-users] force WMS feature source to use certain CS
Fritz Robert
Robert.Fritz at win.ch
Wed Mar 23 08:49:49 PDT 2016
it seems that MapGuide (we use AIMS 2013) does not recognize all CS offered by the WMS server. The server offers 6 or 7 coordinate systems but MapGuide only picks up two (the ones which have a bounding box defined in GetCapabilities).
We now have to switch to a different CS - unfortunately it is one offered by the WMS server but not recognized by MapGuide (or to be more precise by Studio/Maestro). Is there an "easy" way to force MapGuide to use that specific CS? Otherwise MapGuide will perform a transformation on the fly wich will have some negative impact on performance. I downloaded the config.xml via MapAgent for one of the WMS feature sources and I'm wondering if I can just replace the "old" CS with the "new" CS (WKT String, BBOX and EPSG code) and upload the file again. We have 20+ WMS feature sources where I would need to modify the CS used by MapGuide.
Thank you, Rob
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20160323/375dd7be/attachment.html>
