[mapguide-users] Mapguide 3.0 Maestro and Studio problem
Lisa Weber
lisaw at precisionmanagementsolutions.com.au
Tue Mar 29 00:14:45 PDT 2016
Interesting. I experienced the same problem last week on a site but had been running 3.0 on it since November with google maps and bing maps base with no problem - but only when the application definition is loaded using PHP. The bug appeared recently for the PHP code; the google maps simply stopped loading. Not sure what happened as I hadn't changed any code. I'm looking into the Google Maps API currently to see if they've changed any of their calls. They did change licensing requirements last year regarding client API key so maybe there's a flow on effect? Bing maps still works fine if the application definition is loaded using PHP code.
Both bing maps and Google maps fail to load through either Studio or Maestro.
-----Original Message-----
From: mapguide-users [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of GordonL
Sent: Friday, 25 March 2016 12:13 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Mapguide 3.0 Maestro and Studio problem
Yes, I just found that bug with Google in MGOS 3. I don't know if it is submitted yet, but if not I will submit that bug.
Anyone using Google layers in MGOS should wait for fixes with External Maps fixes..before moving to 3.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-3-0-Maestro-and-Studio-problem-tp5242079p5258189.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
