[mapguide-users] How to use ActivityIndicator fusion widget
GeorgesK
georges.kacou at gmail.com
Wed May 11 05:46:19 PDT 2016
Hello all,
I want to display a loading animation in the middle of the screen each time
the map is busy. To achieve this, I thought the ActivityIndicator widget
could do the job, but can't find a clear documentation on how to use it:
- In which container should it be inserted ?
- Should I modify the template file ? How ?
Should there be another method to achieve this goal, I would be glad to read
about it.
Any indication would be highly appreciated.
I am using MagGuide 3.0 with Maestro 6.0.
Thanks in advance.
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-use-ActivityIndicator-fusion-widget-tp5265788.html
