[mapguide-users] Multiple Map Layers in single Application Definition
madhurchanana madhurchanana92 at gmail.com
Thu May 26 22:50:18 PDT 2016
Create a Fusion application, then go to "Maps" and add a 2nd map under
"Currently Available Maps". The map gets added correctly, but you can't
select it. As soon as you select it, you get an error - which means that you
can't configure it, or even delete it.
Error is: System.NullReferenceException?: Object reference not set to an
instance of an object.
at Maestro.Editors.Fusion.MapCtrl?..ctor(IApplicationDefinition appDef,
IMapGroup group, IEditorService edService, IMapWidget widget) in
c:\working\JenkinsCI\home\slave_win\jobs\Maestro
trunk\workspace\Maestro.Editors\Fusion\MapCtrl?.cs:line 105 at
Maestro.Editors.Fusion.MapSettingsCtrl?.lstMaps_SelectedIndexChanged(Object
sender, EventArgs? e) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
trunk\workspace\Maestro.Editors\Fusion\MapSettingsCtrl?.cs:line 119 at
System.Windows.Forms.ListView?.OnSelectedIndexChanged?(EventArgs? e) at
System.Windows.Forms.ListView?.WmReflectNotify?(Message& m) at
System.Windows.Forms.ListView?.WndProc?(Message& m) at
System.Windows.Forms.Control.ControlNativeWindow?.OnMessage?(Message& m) at
System.Windows.Forms.Control.ControlNativeWindow?.WndProc?(Message& m) at
System.Windows.Forms.NativeWindow?.Callback(IntPtr? hWnd, Int32 msg, IntPtr?
wparam, IntPtr? lparam)
View this message in context: http://osgeo-org.1560.x6.nabble.com/Multiple-Map-Layers-in-single-Application-Definition-tp5268467.html
