[mapguide-users] Draw polygon using Javascript API?
Jackie Ng
jumpinjackie at gmail.com
Thu Nov 3 03:12:56 PDT 2016
Yes, mapguide-rest has 2 sample applications that demonstrate how to do this.
1. Editable Published Data
This allows you to do perform CRUD against a feature source configured with
restcfg.json
2. OpenLayers 3 with turf.js
This demonstrates inserting client-side turf.js generated geometries into a
session-based feature source
mapguide-rest can work against many different versions of MapGuide, so if
you are working against the APIs provided by mapguide-rest, you'll generally
be insulated against the underlying MapGuide Server.
And since MapGuide is using FDO, your feature data access / CRUD is the same
process and API, regardless if it's a SDF file, SHP file, SQL Server,
Oracle, etc, etc.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Draw-polygon-using-Javascript-API-tp5292596p5294114.html
